hi WALL Y+ in ske
Old   August 1, 2005, 12:59
Default hi WALL Y+ in ske
latha
hi i am simulating flow past a circular cylinder for subcritical reynolds number using standard k-e model, after getting periodicity in lift and drag while i am checking for wall y+ in cylinder i am getting the value in the range of 1 to 4.5. is it ok?? .as Ske is a high reynolds number model i found in documentation the value of y+ should be more than 30. how can i improve it?? thank in advance Latha.A
Old   August 1, 2005, 18:22
Default Time-averaged volume fraction
dlaw
Hi, I wonder if anyone knows how to obtain the time-averaged phase volume fraction of a certain amount of simulation time for the unsteady case from FLUENT. I appreciate your help. Thanks.
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 15:33
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 00:04
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
