Grid changed after solving in Fluent???
Old   August 3, 2005, 07:21
Default Grid changed after solving in Fluent???
Pah
Hi everybody!
I am using Fluent to solve a grid system, which is made from Gridgen. I run Solver with Steady State, after some iterations I export result into Techplot to check the Grid system, there is changing in grid system. Some cross lines are created.
Somebody explain this problem and how to solve it!
Thanks in advance!
pah
Old   August 5, 2005, 08:57
Default Re: Grid changed after solving in Fluent???
Ralf Schmidt
are you using more than one licences of fluent for iteration?
If so, Fluent seperates to geometrie into several parts. You may see the line on that the communication between two licences took place
Old   August 5, 2005, 09:10
Pah
Thanks for your reply!
I am not sure about "Lisence" that you mentioned. Do you mean that the Fluent version I am using have more than 1 lisence and it creates the error in my grid system?
sincere. pah
Old   August 5, 2005, 09:19
Ralf Schmidt
Something like this happened to me. In our institute we have maximum of 6 licences (that means, Fluent can be run on 6 different computers or for 6 different simulations).
To increase the speed of the iterations I am using sometimes two licences at the same time. And for the communication between the two licences Fluent splits my geometry into two halves. When displaying the results like velocity vectors in Fluent, I see the line were Fluent split.
Old   August 5, 2005, 10:08
Pah
Thanks Ralf!
You said about separation of the domain, and then I checked this problem. In the end, you are right.
It is not problem in Fluent lisence, it is block making problem, I think. Because just in the boundary of 2 block this phenomenon appears only, as in the figure in this link: http://photos1.blogger.com/img/165/5293/640/Grid_2.jpg
Now I am thinking about the solution for this problem, So anybody has some ideas about it?
Sincere. pah
transsonic nozzle with rhoSimpleFoam Unseen OpenFOAM Running, Solving & CFD 8 July 1, 2022 06:54
lift and drag on ship superstructures vaina74 OpenFOAM Running, Solving & CFD 3 June 8, 2010 12:30
Problems with simulating TurbFOAM barath.ezhilan OpenFOAM 13 July 16, 2009 05:55
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 1 November 25, 2008 20:21
Modeling in micron scale using icoFoam m9819348 OpenFOAM Running, Solving & CFD 7 October 27, 2007 00:36
