Time-averaged phase volume fraction
Old   August 2, 2005, 14:45
Default Time-averaged phase volume fraction
dlaw
Hi, I wonder if anyone knows how to obtain the time-averaged phase volume fraction of a certain amount of simulation time for the unsteady case from FLUENT. I appreciate your help. Thanks.
dlaw
Old   August 2, 2005, 15:30
Default Re: Time-averaged phase volume fraction
pUl|
I'm not sure, so please check. I think fluent has an option called 'data sampling for time statistics' or something.
Old   August 2, 2005, 16:29
dlaw
Hi, I tried 'data sampling for time statistics' but I did not see any option for the time-averaged volume fraction after I run the simulation. Thanks for your reply.
Old   August 2, 2005, 18:31
us
Select 'data sampling for time...' option in iterate panel of unsteady calculation. Run the calculation. Then while postprocessing, you will be able to select 'unsteady statistic' option in a drop down listbox of contours or vectors or xy plot etc panel. With that, you would see mean velocity, mean volume fraction and also the mean rms values.
Regards -US
Old   August 3, 2005, 10:58
dlaw
Hi us, I wonder if we can start time-averaging the data after certain amount of time. For example, I would like to time-average the data only after 10 sec in the simulation up until 60 sec. Thanks for your reply.
Old   August 3, 2005, 13:33
us
Certainly you can do that. Initially don't select 'data sampling..' option. Calculate until first 10 sec end. Select 'data sampling..' and continue calculation until the time you want. Doing that, mean values doesn't account for first 10 seconds results and I think, that is what you want to do. -US
Multiple floating objects CKH OpenFOAM Running, Solving & CFD 14 February 20, 2019 09:08
Volume fraction of dispersed phase to determine DPM, VOF, Mixture model Mohsin FLUENT 5 March 5, 2018 07:47
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
