Starting 3D simulation with ideal gas – f.p.error
Old   August 5, 2005, 06:59
Default Starting 3D simulation with ideal gas – f.p.error
Ralf Schmidt
I am running a simulation of a 3D geometry with air at constant density and it works very fine.
Now I changed the air properties to ideal gas (there are up to 3 bars pressure on my device). When I start iterating, the floating point error occurs. Even when I set courant number to 0.1 and at the mass flow inlet boundary ant pressure outlet boundary all turbulence values to 0.1 (k-epsilon) the floating point error occurs before the first iteration is finished.
What is wrong? Any help is highly appreciated!
Ralf
Old   August 5, 2005, 09:39
Default Re: Starting 3D simulation with ideal gas – f.p.er
Swarup
I am not sure but it may be due to bad input/initialization. Since you said that error occurs before the first iteration is over, it indicates to some problem with your input data.
Swarup.
Old   August 5, 2005, 09:58
Ralf Schmidt
thanks for your answer! My input (inlet into the geometrie) is just a constant mass flow rate normal to boundary. That works fine for the constant density simulation. Or what kind of input do you maen?
Ralf
Old   August 5, 2005, 10:46
Default Re: Starting 3D simulation with ideal gas ? f.p.er
Swarup
I mean inputs other than boundary data like those in initialization, property data, etc.
Old   August 5, 2005, 15:57
Default 3D simulation with ideal gas
alex
Hi
I had a similar problem with the initialization but when I initialized my model, appeared both, a pressure limited and viscosity limited on all cells before I began the iteration process. What can I do?
Alex
Old   August 5, 2005, 22:52
Default Re: 3D simulation with ideal gas
Swarup
answer to this problem can be found in the User-Guide. if you see the message viscosity limited to ----- in ---cells and pressure limited to--- in ---- cells, then it has something to do with your problem set-up. your variables of interest reach the maximum/minimum limit set to prevent solver from crashing. FLUENT user guide tell that you should review your problem set-up with respect to type and quality of grid, appropriate boundary conditions, etc.
Swarup.
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
exhaust gas simulation jai CFX 1 November 23, 2009 04:23
Gas plume or flare simulation ahourri FLUENT 0 November 14, 2005 09:23
ideal gas law in turbulent flow Achim Siemens 0 March 26, 2003 14:38
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 22:02
