Compressible, turbulent flow in a pressure tube
Old   August 4, 2005, 04:23
Default Compressible, turbulent flow in a pressure tube
Mario
Dear all,
I am trying to compute air flow through a total-pressure tube with the segregated solver. The flow is compressible (ideal gas law) at Ma=0.26 and turbulent (standard k-e). I am using velocity-inlet and pressure-outlet as boundary conditions. I have set the operating pressure to zero. Unfortunately I cannot get the solution converged. Either I get a divergence detected in pressure correction or the residuals are oszillating. Any suggestions are highly appreciated!
Old   August 5, 2005, 08:21
Default Re: Compressible, turbulent flow in a pressure tub
lily
for the second question, you should adjust your grid. hope any help.
Old   August 9, 2005, 01:47
john
Mario,
You cannot use a velocity inlet boundary condition with a compressible fluid. You need to use either mass flow inlet or pressure inlet. If you know the inlet velocity, you can calculate the inlet mass flow ok.
Outlet pressure for compressible flow Michelle CFX 12 September 1, 2015 18:38
solver for subsonic compressible turbulent flow in OF 1.7 nileshjrane OpenFOAM Running, Solving & CFD 20 February 13, 2012 05:54
compressible steady/transient turbulent flow orlikev OpenFOAM Running, Solving & CFD 1 November 1, 2010 07:16
pressure distribution in water flow, differences in icoFoam and COMSOL deniggo OpenFOAM Running, Solving & CFD 14 September 30, 2010 03:48
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
