August 6, 2005, 12:17 |
Particle injection
Hi.
I am going to inject some particles into an air flow in a duct which has one inlet and two outlets. The outlet ducts have diffetent sizes, so I want to see what portion of the particles go in each outlet. The size and mass of particles can be ignored in case can simplify the things.The problem may be steady state or transient. Could somebody kindly tell me what is the best way to simulate the injection of the particles? Thanks, Mazyar |
August 6, 2005, 14:20 |
Re: Particle injection
Discrete phase model. Transient. If the behavior is steady state, it will show up.
August 10, 2005, 08:30 |
Mazyar,
I am studying a similar model. I am calculating the fraction of discrete particles travelling through a side arm on a T junction. I can simulate it, but need to know the mass fraction through each outlet. Do you have a good method to calculate the relative fraction of particles travelling through each outlet? Thanks john. |
August 10, 2005, 11:55 |
John,
I think, you must specify the type of both outlets as OUTFLOW. By doing this, FLUENT will calculate the fraction at each exit. Mazyar |
May 22, 2017, 17:01 |
Deposition Particle coordinate
Anu
Rep Power: 8 |
I am working on Aerosol Particle deposition in the specific region of human lungs. At this stage I am struggling on How to get deposited (or trapped) particle coordinates in fluent. Your help would me much appreciated. Thanks in advance. Anu QUT |
Particle Injection Mass Flow Rate and Position | leonozx | FLUENT | 3 | March 9, 2018 09:58 |
Particle injection boundary condition | fjalil | CFX | 8 | September 23, 2009 09:40 |
DPM UDF particle position using the macro P_POS(p)[i] | dm2747 | FLUENT | 0 | April 17, 2009 01:29 |
Particle Injection File or DEFINE_DPM_INJECTION_IN | Dave | FLUENT | 0 | January 18, 2008 13:16 |
Particle velocity - Injection With Line Weighting | Danuta | CFX | 0 | October 10, 2007 06:21 |
