-   -   udf compile error (http://www.cfd-online.com/Forums/fluent/37510-udf-compile-error.html)
rawin August 8, 2005 03:31
udf compile error
Hi; I use this Udf to define unsteady velocity inlet profile.
unsteady.c #include"udf.h" DEFINE_PROFILE(unsteady_velocity, thread, position) { face_t f; begin_f_loop(f, thread) { real t=RP_Get_Real("flow-time"); F_PROFILE(f, thread, position)=20.+5.0*sin(10.*t); } end_f_loop(f, thread) }
but when I compile it, Fluent report this error: cpp -ID:\FLUENT.INC\fluent6.0/src -ID:\FLUENT.INC\fluent6.0/cortex/src -ID:\FLUENT.INC\fluent6.0/client/src -ID:\FLUENT.INC\fluent6.0/multiport/src -I. -DUDFCONFIG_H="<udfconfig.h>" unstveloc.cError: unstveloc.c: line 1: parse error. what should i do?please help me. thanks.
Vinod Dhiman August 8, 2005 08:58
Re: udf compile error
Firstly, don't use cpp, use g++ or c++. I check it out, where is the problem, and let you know if there is any.
Vinod Dhiman
Vinod Dhiman August 8, 2005 09:53
The mistake is in defining variables. Firstly define variable, then start program. You have to define real t before starting f_loop.
Vinod Dhiman
rawin August 8, 2005 13:58
Hi vinod; I check it,but the error appears again.
Vinod Dhiman August 8, 2005 14:01
Compile it after making the changes I told you. Define t out of the loop
Vinod Dhiman
Vinod Dhiman August 8, 2005 14:25
Else send me your ID. I'll send you a file. Make sure you have udf.h file in the same directory where you .c file is.
Vinod Dhiman
rawin August 9, 2005 05:40
After making the changes you told,I compiled it. But it didn't solve the problem. rawin.
Vinod Dhiman August 9, 2005 07:19
Is it still giving the same error. You send me your ID. I'll send you the file.
Vinod Dhiman
rawin August 9, 2005 10:29
ok the same error. my ID:rawin_ch@yahoo.com
rawin August 15, 2005 05:29
Hi vinod. I solved the problem I Was reading Fluent 6.0.12 .cas file to Fluent 6.018.
