Home > Forums > FLUENT
parallized UDF
Old   August 10, 2005, 11:56
Default parallized UDF
matong
HI,there! Does anybody ever do some researches using parallized UDF? I try it the whole day, but can't tackle it! Can anybody show me the step of using UDF in parallel version. (I'm using windows network for parallized running) Thx!
Old   August 10, 2005, 12:25
Default Re: parallized UDF
Vinod Dhiman
Hi
Don't you have documentation for parallel UDF's. What kind of udf are you writing. I mean for what purpose. If you don't have documentation, I can send it to you in pdf format.
Vinod Dhiman
Old   August 11, 2005, 02:30
matong
HI,Vinod Dhiman I do have the udf documentation, but I can't load the compiled libudf. The following is a simple parallized udf I copied from the documentation. I want to use it to test the procedure of using parallized udf. First, I launch the fluent in parallel version.(Windows Network) Then I load the case file in the fluent host. After that, I compile the following udf and get the library named "libudf".(the directory containing the libudf and case file have already been shared). Finally, i load the "libudf" . An error appears.
so, could you give me some advise!! Thx! #include "udf.h" DEFINE_ADJUST(where_am_i, domain) { #if RP_HOST Message("I am in the host process\n"); #endif /* RP_HOST */
#if RP_NODE Message("I am in the node process with ID %d\n",myid); /* myid is a global variable which is set to the multiport ID for
each node */ #endif /* RP_NODE */
#if !PARALLEL Message("I am in the serial process\n"); #endif /* !PARALLEL */ }
Old   August 11, 2005, 05:18
Luca
What kind of error do you get? Are you sure you're compiling the UDF for the parallel solver. Go to your UDF directory/ntx86: if you see 3ddp_host and 3ddp_node or (3d_host and 3d_node depending of your analuysis) the UDF is for the parallel. Luca
Old   August 11, 2005, 13:09
Vinod Dhiman
Yes, can you tell what is the error you are getting
Vinod Dhiman
Thread Tools
Trackbacks are On
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 23:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 21:38
Dynamic Mesh UDF Qureshi FLUENT 1 December 2, 2009 01:27
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 05:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 05:01
