Precision in Fluent6
Old   August 12, 2005, 04:25
Default Precision in Fluent6
mitchoum22
I'm a student from Catholic University of Louvain, Belgium. I work on Fluent for my end of studies report.I wanted to know which precision on flow caracteristics we can expect?It will depend on the mesh quality and residuals level i guess...? If someone can help me find a idea..it would be usefull for my work.
Thanks
Old   August 12, 2005, 05:25
Default Re: Precision in Fluent6
Laika
On some models Fluent is as accurate as you want it to be (or as accurate as you can pay for). On other models fluent calculates very accurate results with inaccurate models. Are all the assumptions of the submodels you used valid for your problem? Is your turbulence model the best for your application, and if so, is it enough? Accuracy depends on hundreds of things, but not on residual levels!!!! The only information that you can exstract from residuals, is whether or not your simulation is stable and moves in the right direction. It's a compass, not a GPS-system! It will never tell you were you are.
With the information you have given us, your question cannot be answered.
good luck, Laika, still orbiting
Switch from single precision to double precision kk81 OpenFOAM Bugs 0 March 11, 2010 06:14
Number of elements x double precision matheusguzella ANSYS Meshing & Geometry 2 October 7, 2009 10:15
Double precision & User Fortran Martijn CFX 3 April 4, 2009 05:43
what's wrong about my code for 2d burgers equation morxio Main CFD Forum 3 April 27, 2007 10:38
double precision assigning in FRTRAN R.A.Khurram Main CFD Forum 12 October 2, 2001 11:00
