Display of Density
Old   August 13, 2005, 11:32
Default Display of Density
Endee
Hi, I get the display of density as checker board (like distorted pixel image)...without any variation in the value. I am not using ideal gas.. What can be the reason? Regards
Old   August 14, 2005, 07:24
Default Re: Display of Density
Laika
if you look athe schale, you will probably see that the minimum and the maximum are the same. My guess is that you are looking at a uniform density field.
suggestions: change the scale as such that min and max are at least slightly different. Do you see the constant density field? If so, and if you think density variations in your flow problem are important: do not use a constant density material.
Laika, still orbiting
A problem about density in liquid air definition alloveyou CFX 2 June 14, 2012 14:20
Variable Density Function ryzd FLUENT 1 August 25, 2011 14:16
REAL GAS UDF brian FLUENT 6 September 11, 2006 08:23
Warning 097- AB Siemens 6 November 15, 2004 04:41
variable density water Atit Koonsrisuk CFX 2 July 24, 2003 03:07
