MidAngle Skew
Old   August 13, 2005, 05:24
Default MidAngle Skew
Swarup
To all,
I want to know which value for theta should be taken to calculate MidAngle skew in Gambit? In the definition, theta is taken as minimum and for hex, it is written as max.
Thanx,
Swarup.
Old   August 13, 2005, 13:10
Default Re: MidAngle Skew
Balaji
Hi
This is the thing I understood from the manual Mid angle skew is cosine of the minimum angle formed between the bisectors of the element edges (quadrilateral) or faces (hexahedral)
For Quads we have only two bisector lines which makes four angles. Out of that take the minimum angle.
For Hex's we have three possible ways of getting bisectors.each will have four angles.Take the minimum of the four.This way you will get three angles for three possible bisectors.Take the maximum of the three.
I hope I have understood it correct.
Old   August 14, 2005, 00:06
Swarup
Seems OK. Thank you for the response Balaji.
Swarup.
Cell skew Factor prapanj OpenFOAM Pre-Processing 7 August 25, 2013 15:44
Skew factor of decomposeParDict jms OpenFOAM 1 May 29, 2013 12:12
Avoiding Skew in Tight Corners Marc FLUENT 4 July 23, 2007 15:21
how to reduce Cell Equivolume Skew santosh FLUENT 1 August 16, 2005 14:38
grid aspect ratio and skew Darcy CFX 2 March 10, 2001 01:52
