Channel flow simulation
Old   August 13, 2005, 14:38
Default Channel flow simulation
Ben
Hi, I am trying to do turbulent channel flow simulations. I need to use periodic bc in x and z directions. I specify a pressure gradient in the periodic panel. I do not get any flow structures. how do i specify any some disturbances in the flow and make sure that they are sustained?
Old   August 14, 2005, 07:19
Default Re: Channel flow simulation
Laika
"any flow structures" What are you looking for?
What turbulence model have you used? What kind of disturbances do you want to initiate? Is their sustaining physical?
Please somewhat more info to work with...
Laika, still orbiting
Old   August 14, 2005, 16:31
Ben
well I am trying to validate a new hybrid turbulence model with the DNS data of moser et al. at Re_tau of 640. So they use periodic bc in both streamwise and spanwise directions. I generated a case file by implementing periodic bc in both streamwise and spanwise directions and then for the periodic bc, I chose the pressure gradient as driving force. I am unable to get flow structures of any sort. I want to create some velocity diturbances which are sustained. How do I create an initial velocity fluctuation and sustain it? This is a transient simulation. Sunil
Boundary condition problem for open channel flow Andy CFX 9 June 11, 2016 07:20
Simulation of a complex wing in solidworks flow simulation niels1900 FloEFD, FloWorks & FloTHERM 6 April 20, 2011 10:44
gas flow out of a C-D channel ljp FLUENT 0 March 7, 2011 14:32
Natural convection - Inlet boundary condition max91 CFX 1 July 29, 2008 20:28
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
