UDF error
Old   August 16, 2005, 15:47
Default UDF error
Aireen
I really need a help here. I am having a nmake error "nmake is not recognized....." when trying to compile an udf example given in the tutorial. When I interpret the udf it works fine. I've set the environment and correct the path as suggested by fluent. I started my fluent from the compiler, I'm using Microsoft Visual C++ Toolkit 2003. Pls anyone help me. I've been having this problem for more than 3 weeks!
Old   August 16, 2005, 15:51
Default Re: UDF error
pUl|
please search this forum using 'nmake' as a keyword. Several people have faced a similar problem and it has been solved.
Old   August 16, 2005, 16:56
shiva
r u sure u were supposed to interpret it and not compile it?
Old   August 16, 2005, 17:45
Aireen
Shiva, I'm not sure. I just try to see any of those (interpret and compile) will work on my computer. B4 I made a few changes, I can't even interpret the udf.
Old   August 16, 2005, 17:46
Aireen
I did, but none of them work.
Problem with UDF compiling for kTkLW model Wantami FLUENT 0 July 18, 2011 05:11
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 06:42
Accessing phi from a fvPatchField at same patch johndeas OpenFOAM 1 September 13, 2010 20:23
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
