-   -   Unsteady aerodynamic analysis of Airfoil (http://www.cfd-online.com/Forums/fluent/37604-unsteady-aerodynamic-analysis-airfoil.html)
Kyung-Seok, Kim August 18, 2005 02:04
Hi, everyone. I'm trying to analyze unsteady aerodynamic analysis. The model is airfoil.
but, 1.How can I do this with "Fluent" ? (I can obtain steady result.)
2.How can I get the "unsteady pressure coefficient"?
and I'm beginer in aerodynamics, so can you recommend some reference materials(book,thesis, or website)?
Thank you in advance.
Miqdad August 18, 2005 15:12
Re: Unsteady aerodynamic analysis of Airfoil
Well, unsteady analysis are always time dependent. I guess you should be having your airfoil at a reasonable angle of attack to capture those bluff body shedding.
Hope this helps!
helper August 22, 2005 15:28
Since you're interested, don't you think you need to do transient simulation? You can activate unsteady option in the "Define/Models/Solver" panel. Choose "Unsteady in the "Time" box, and "2nd-order implicit" in the "Unstesdy Formulation" box. Determine the time-step size so that you have a sufficient number of time steps (>50 e.g.,) per the expected period of the vortex shedding. Use the steady solution as an initial guess for your transient computation. See if there's any tutorial on unsteady flow simulation.
