Gambit - display dimensions
Old   August 19, 2005, 02:21
Default Gambit - display dimensions
osh
Is there a way of displaying the coordinate values/dimensions of the geometry in Gambit?
I need to know these so that I can define certain surfaces in Fluent.
Thanks
Old   August 19, 2005, 02:44
Default Re: Gambit - display dimensions
Balaji
You can see the coordinate value of vertices by summarising the vertices.It will display the coordinate values.
Old   August 19, 2005, 22:04
osh
In Fluent or Gambit?
Old   August 20, 2005, 01:55
Balaji
In Gambit.Summarizing the edges will give you edge length.
Old   August 22, 2005, 04:33
osh
Thank you Balaji for your help.
Display delay in Gambit wateraction ANSYS Meshing & Geometry 2 November 3, 2011 01:25
GAMBIT display pro, under VISTA aldon ANSYS Meshing & Geometry 8 September 11, 2011 11:14
Gambit - Odd Display -with out text - in Linux (OpenSuse 11.2) pradeepmohanm ANSYS Meshing & Geometry 1 December 20, 2009 11:17
how to display parameter values in GAMBIT yueke FLUENT 1 June 29, 2009 02:44
GAMBIT: recalling the dimensions Susan FLUENT 1 July 6, 2007 23:47
