FLUENT and 6.0 and 6.2
Hello all,
Just a quick qauestion here. In terms of accuracy of results, will FLUENT 6.0 and 6.2 give the same results? That's all. Thanks. Sham. |
Re: FLUENT and 6.0 and 6.2
hi they should give ame result if we use same solution settings i mean models and numerical schems etc.
You will most likely see an appreciable difference between 6.0 (or 6.1) and 6.2. True, any change in the solutions from version to version is often frowned at. The good news is that 6.2 significantly - often dramatically - improves spatial accuracy especially on unstructured (tetrahedral, triangular, wedge, etc.) meshes.
