August 22, 2005, 06:40 |
combustion modeling
i want to model combustion of a candle,we know candle flame is a non_premixed and laminar flame,so I use Transport Species option for modeling,but my model couldn't converged?do you know what's the reason?
August 23, 2005, 04:23 |
Re: combustion modeling
Hi sara, Using Transport Species is correct but there is some poits that you must pay attention to it:1)you should choose "volumetric" option to have reaction and therefore convergence,if you don't do that you'll have only the flow field. 2)three other choices are in the box that the "Thermal Diffusion" is most important option that I think(by experience) is neccessary for diffusion (non-premixed) cases. Hope to Help you
August 23, 2005, 06:22 |
Thank you for your answer,but I have some other problems too,I would be gratefull if you help me: 1-Is it necessary to active Radiation option? 1-In my modeling I have Pressure-far-field boundary condition and i should input mach no.what's your suggestion (the air around candle is stable and don't have movement) 3-can I use out_flow boundary-condition in this model? Sincerely
August 24, 2005, 03:47 |
Hi sara 1)Radiation option is not necessary and doesn't have any important effect on the solution (unless the main phenomenon of your problem is radiation)2)I do not think that pressure far field and mach no. would be important for a candle problem.3)what do you mean about out_flow region in this case?
August 24, 2005, 14:44 |
Hi Mohsen,My project is 2D:suppose a rectangle that a candle is on its lower edge, I model this shape in GAMBIT and subtract candle from rectangle, there is air in this shape and melted-paraffin enter this zone. At first I decided to define BC like this: Left & right edges of rectangle as pressure-far-field, top edge as outflow, the edge that melted-paraffin enters as mass flow inlet, but I faced some problemes: 1-I think it is an incompressible flow(velocity is small),so I couldn't use pressure-far-field BC. 2-In Heat transfer problems I couldn't use out-flow BC. So I tested another appropriate BC,but I couldn't find them, and I couldn't reach to a true modeling.could you please help me?
sincerely |
Combustion modeling | SuperPahan | CFX | 6 | September 9, 2010 11:57 |
combustion modeling help | Krish | Main CFD Forum | 2 | November 3, 2008 15:43 |
question about modeling combustion | xinhui zhang | FLUENT | 1 | December 16, 2007 19:40 |
A role of combustion modeling in flow solver? | Yoon | Main CFD Forum | 0 | November 26, 2006 12:00 |
Combustion Modeling | Pravin Naphade | FLUENT | 0 | May 27, 2004 02:51 |
