-   -   display filled contour of temperature gradient (http://www.cfd-online.com/Forums/fluent/37649-display-filled-contour-temperature-gradient.html)
Frederik August 22, 2005 10:02
Hi ,
I have a 2D temperature distribution in the domain and I want to display temperature gradient profile (filled coutour) ... any body can tell me how can I get this distribution as a contours in all the domain .., and how to specefy the component of the gradient vector dT/dx ,dT/dy....
thanks in advance friends... frederik
Masood August 22, 2005 14:10
Re: display filled contour of temperature gradient
hi fredrick
in the display menu goto contours. then from pull down menu slect temprature. and check the filled option. and u will get the temprature cotours.
chao...
helper August 22, 2005 15:05
You can have access to the temperature gradients if you activate the "expert" menu. This is how to activate it. In the TUI ("/solve/set"), type "expert" and say "y" (yes) to the propmt saying "Keep temporary solver memory from being freed?". Do one solver iteration, and you will find temperature gradients in the drop-down list in the Contours/Derivatives panel.
masood yooceframandi August 22, 2005 18:23
dear helper! would you tell me please,where did you read about this way!i mean "solve/set/expert...".would you tell me please? and then,i did that but i cant plot dT/dX contour because an error occurs.why? regards
Frederik August 23, 2005 05:42
Dear helper thanks a lot for your answer ...
but what I want to obtain is countour of temperature gradient for a transient simulation after at t= 2.5 s..
should I use "solve/set/expert and run the iteration for only one time step ,??
regards frederik
