LES
Old   August 12, 2005, 13:25
Default LES
wilson
hi
i am performing a LES aerodynamic flow analysis analysis of passenger medium size car. i completed a steady state realizable K-e flow analysis of 100 iteration. now i am continuing my LES analysis from steady state results. i have used smagoriswky-lilly model and given 0.0003 secs as the time step. in residual plot i get an oscillating curve which is neither diverging nor converging. is this residual plot correct? have any of u performed such a analysis, maybe he/she can share his difficulties faced. since i am bit new to fluent can any one guide me how to make animation of the above analysis.
thanks and regards wilson
Old   August 22, 2005, 15:35
Default Re: LES
helper
If you chose an adequately small time-step size, the solution normally converges within 10 iterations each time step. So, try a smaller time-step size, let's say, 1e-4. If you're using 6.2, try the non-iterative time-advancement (NITA) scheme which can be selected in the "Define/Models/Solver" GUI panel.
How to conduct transient LES simulation tianrenshui311 FLUENT 0 November 15, 2010 13:21
Turbulence dampening due to magnetic field in LES and RAS eelcovv OpenFOAM 0 June 8, 2010 11:35
LES grid mesh L3munoz Main CFD Forum 0 April 7, 2010 05:05
Differences between a laminar code and a les one ben Main CFD Forum 9 February 16, 2005 23:40
Some Questions about LES. Bin Li Main CFD Forum 2 February 20, 2004 09:58
