August 22, 2005, 21:33 |
oil flow
I would like to know more about the 'oil flow' option within the pathlines panel. Can this be used to simulated a very thin lubricant boundary layer on the inside of a pipe wall?
I cannot do this using the VOF model since the mesh size on the wall must be very very small. The lubricant layer needs to be only a few mm thick. |
August 23, 2005, 11:09 |
Re: oil flow
As far as I know that option has nothing to do with numerical modeling or solution techniques but it is just a post processing tip that displays the pathlines constrained to lie on a particular wall, if I'm not wrong...
Cheers Edi. |
Display Modes | |
Compressible flow, no data at the outlet | mireis | FLUENT | 6 | September 3, 2015 02:10 |
Flow meter Design | CD adapco Group Marketing | Siemens | 3 | June 21, 2011 08:33 |
Solid partilcles + oil flow | suresh | OpenFOAM Running, Solving & CFD | 2 | February 1, 2011 05:08 |
Lubricant oil, two phase flow | Rikio | CFX | 0 | December 30, 2008 21:08 |
transform navier-stokes eq. to euler-eq. | pxyz | Main CFD Forum | 37 | July 7, 2006 08:42 |
