Compiling problem
Old   August 22, 2005, 10:43
Default Compiling problem
Alper Albayraq
Hi I am new fluent user. I cannot compile the tuterial file(dynamic mesh example)(valve.c) from the COMPILED UDFs Panel and when I press the build button i recieve this message
('nmake' is not recognized as an internal or external command operable program or batch file.) and then when i load it i recieve this error
(Error: open-udf-library: the system cannot find the path specified)
what should i do?
Regards, Alper
Old   August 22, 2005, 11:12
Default Re: Compiling problem
Aireen
I am having the same problem and still could not solve it!!!! What compiler are you using?
Old   August 22, 2005, 12:52
Alper Albayraq
Hi
I dont know whether fluent needs another outof-fluent compiler such as visual c++ for compiling in itself. Because in fluent help I read such sentences
1.Compiled udf's are build in the same way that the fluent executable itself is build
2.A script called "Makefile" is used to invoke the system C compiler(???) to build an object code library
3.The object code library contains the native machine language translation of your high level c source code
4. This shared library is then loaded into fluent at runtime by process called "dynamic loading".
If you say that "Yes it needs outof-fluent C compiler" then I ask how fluent finds the path of your C compiler?
After all it is better that i answer your question. Yes I have a (Microsoft visual c++ 6) installed in my computer.
Thanks for your attention, Alper
Old   August 23, 2005, 08:35
Jimmy Fox
Please work in Command Prompt Window of C++, and launch Fluent, then try to compile UDF. It may work.
Old   August 24, 2005, 02:08
Suvash
You should keep your UDF file in the temp directory of your computer...
Old   August 25, 2005, 00:54
Alper Albayraq
Hi
I finally could compile the file having visual c++ 6 installed in my computer. thanks for all of you for your attention. See you in other problem!
Best Regards, Alper
Old   August 25, 2005, 12:46
hari
Try this You need to follow the following steps 1) set up the environmental variable This is done by going to the start menu > Programs>Fluent> Set_environment clicking this would set the path and variable. 2) set up a directory structure as follows create a dir libudf in that create "src" and "ntx86". In ntx86 create "3d".( am asuming that ur simulation is 3d) 3) copy the udf (.C file) and the required header( u can get the header files frm c:\FLUENT.INC\fluent6.*.*\ntx86\src) files into the "src" folder. 4) go to c:\FLUENT.INC\fluent6.*.*\ntx86\3d copy the contents into the 3d folder which you created. 5) go to c:\FLUENT.INC\fluent6.*.*\ntx86\src copy makefile_nt.udf and user_nt.udf to your 3d folder 6) rename makefile_nt.edf to makefile and open user_nt.udf and read the instructions and do accordingly. 7) close FLUENT . Open command prompt ( start > accessories > command prompt ) type the following C:\ CD program Files \ microsoft visual studio .net\vc7\bin 8) type :- vcvars32 9)go to the libudf\ntx86\3d which u have created 10) type nmake 11) This will compile ur code and build a lib if u dont have any errors , if errors are present it will say so u need to debug it then. 12) once this is done u can open fluent again and load the lib u have just created , in this case it would be libudf.
hari
Old   August 26, 2005, 01:39
Alper Albayraq
Hi hari
Thank you very much indeed. Your guidance realy worked very well. But I have some more questions. Sorry for my ignorance.I am not well in computer science.
1:What vcvars32 does?
2:Then what nmake does?
3:why when i work with (Visual c++ 6) rather than (visual studio.net) there is no need for such steps you've mentioned?
4:when fluent solve a case which have a compiled udf, Does fluent use out-of-fluent compiler(such as visual c++) in the same time when it iterates?
Thanks for devoting your time for me.
Best regards, Alper
Problem compiling OpenFoamTurbo troy OpenFOAM 3 December 4, 2020 14:08
my problem wuth UDF compiling m.beh FLUENT 3 November 22, 2011 00:47
Problem in Compiling the solver m.maneshi OpenFOAM Running, Solving & CFD 4 November 3, 2010 02:07
problem in compiling UDF ammi reddy FLUENT 1 December 1, 2006 06:45
UDF compiling problem in Windows Mazyar FLUENT 1 April 26, 2006 01:48
