combustion modeling
Old   August 26, 2005, 15:19
Default combustion modeling
sara
Hi friends,any one can tell me In combustion modeling how would we find the height of the flame? and What's the meaning of 'divergence detected in AMG solver :temperature' and what's its reason?
Old   August 31, 2005, 03:56
Default Re: combustion modeling
antonietta paulozza
hi, when there is a message of divergence detected in temperature the reaspns can be : - an error of the definition of boundary condition, which is the most probable reason.You should check the boundary condition. - a not well defined mesh, you should use a finer mesh - a problem of density law.what kind of density law are you using?
Old   August 31, 2005, 06:18
sara
Hi antonietta Thanks for your reply,I use incompressible ideal gas B.C, and when I use a finer mesh this message of divergence didn't detected.
Old   August 31, 2005, 07:54
antonietta paulozza
well, so you have solved your problem.I have had the same problem and it was due to the mesh too. good luck anto
Old   September 5, 2005, 06:37
MANOJ KUMAR
HI I FIND U PROBLEM ALSO DO THE INCREASE TEMPERATURE LIMIT IN THE FLUENT WHEN U STARTING INTILIZATION
Combustion modeling SuperPahan CFX 6 September 9, 2010 11:57
combustion modeling help Krish Main CFD Forum 2 November 3, 2008 15:43
question about modeling combustion xinhui zhang FLUENT 1 December 16, 2007 19:40
A role of combustion modeling in flow solver? Yoon Main CFD Forum 0 November 26, 2006 12:00
Combustion Modeling Pravin Naphade FLUENT 0 May 27, 2004 02:51
