modelling two phase in fluent
Old   August 26, 2005, 00:39
Default modelling two phase in fluent
Sumeet
I want to model the surface of water heated in a container. For this I need to take the water-air interface into account. Please suggest any two phase model method.
Thanks
Sumeet Kumar
Old   August 26, 2005, 05:30
Default Re: modelling two phase in fluent
FREDERIK
hi sumeet ,
do you want to model water evaporation ? if so , I think you have to use vof model with 2 phases air + water ... could you please expalin more your physical model ?,
Old   August 26, 2005, 07:03
Sumeet
I have to model the free surface of water in a square cavity whose left and right walls are maintained at fixed temperatures , bottom wall is insulated and the top surface is exposed to atmosphere. Basically I have to ensure that the surface generated is such that the pressure is constant over it. Can you also explain the procedure to use the correct model?
Thanks in advance
Sumeet
Old   August 26, 2005, 07:05
Sumeet
The whole problem is under steady and lamionar assumption and I am using Boussinesq model for convection. If you have a better method then pls suggest
Thanks Sumeet
Old   August 26, 2005, 16:17
sulfi
use VOF model with geo re-construct scheme, divide the domain with sepearte face for air-inlet n water-inlet. an example is given in fluent tuts, u can go through it. regards sulfi
(help) three phase simulation on fluent sincity FLUENT 0 July 20, 2011 00:19
Discrete phase model -FLUENT s567d Main CFD Forum 0 March 15, 2011 06:36
Engine modelling using fluent - advice nat2479 FLUENT 0 February 1, 2011 14:18
Modelling a "Rolling Road" in Fluent Nick Main CFD Forum 0 August 11, 2007 03:59
multi phase modelling in fluent naren FLUENT 1 January 25, 2005 12:31
