August 29, 2005, 04:36 |
strange Fluent error
Hi! I am simulating combustion of solid fuel in 3d case. When simulation reaches iteration n.° 500 Fluent gives the following error:
999999 (mpsystem.c@1210): mpt_read: failed:errno=104 999999: mpt_read: error: read failed trying to read 4 bytes: connection reset by peer IO error the fluent process could not be started. What does this error mean? How can I avoid it? Thanks. |
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 13:21 |
nonNewtonian viscosity model | mhassani | OpenFOAM Programming & Development | 5 | January 7, 2013 09:27 |
error while running paraFoam! | padmanathan | OpenFOAM | 9 | October 13, 2009 05:17 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
Problems of Duns Codes! | Martin J | Main CFD Forum | 8 | August 14, 2003 23:19 |
