August 12, 2005, 20:17 |
polyflow import of neutral files
I have created a *.neu file using gambit for polyflow solver. However,I cannot convert the *.neu file into polyflow using polyman. Could please help me with the procedure. Thanks.
August 29, 2005, 17:12 |
Re: polyflow import of neutral files
You need to open a polyman session with other existing problem ( for example, a tutorial problem, this is needed to acces Polydata ) then you have to run polydata. In Polydata you clik CONVERT MESH FILE and select the .neu file you wish to convert into a .msh file.
Converting Fluent mesh files to Gambit neutral files | samuelkc | ANSYS Meshing & Geometry | 9 | April 21, 2021 06:28 |
UDF issue | MASOUD | Fluent UDF and Scheme Programming | 14 | December 6, 2012 13:39 |
critical error during installation of openfoam | Fabio88 | OpenFOAM Installation | 21 | June 2, 2010 03:01 |
Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 07:21 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
