fluid-solid heat transfer?
Old   September 21, 2009, 17:25
Default fluid-solid heat transfer?
Felipe Gutiérrez Donoso
Figd84 is on a distinguished road
I´m trying to predict the heat transfer between a hot air channel and a solid ball inside it. But I can´t, because the equations coupling only works in the solid-fluid way.
The heat transfer and fluid mechanics equations are only solved in the fluid region, and the temperature inside the ball remains constant, with no heat transfer to the sorrounding air (using coupled boundary conditions).
I tried to solve the problem in diferent way and it works. The ball was fluid and the channel was solid, with temeperature boundary conditions.
Can I do fluid-solid heat transfer in FLUENT?? (not using convective boundary conditions)
Regards
Figd84 is offline   Reply With Quote
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Solid / Fluid Heat Transfer Koranten FLUENT 3 March 19, 2011 07:21
Heat transfer trough a solid domain Tiago CFX 2 March 17, 2008 14:54
modeling heat transfer betwwen fluid and solid Al Mazdeh CFX 0 March 13, 2008 10:35
Water vapour condensation in CFX-5.7.1 hdj CFX 1 November 27, 2005 07:15
