September 1, 2005, 13:21 |
Calculate erosion rate??
hi how can i use FLUENT to claulate erosion rate in metals parts.
September 2, 2005, 06:47 |
Re: Calculate erosion rate??
Yes. There is a tutorial about that
September 2, 2005, 11:44 |
you need iterate your case file until will converge. next to it, in the define-model-phase discrete, you need turno on the iteration with continuous phase and set some kind of injection. In the fluent tutorial you can search the explain about the steps that you should follow.
September 8, 2005, 02:04 |
which tutorial are u referring to?
Regards Rajeev |
How to calculate particle mass flow rate at outlet | Randy | FLUENT | 6 | April 29, 2020 13:47 |
calculate mass flow rate on face OpenFoam | ronaldo | OpenFOAM | 7 | November 8, 2019 00:10 |
Using "patchIntegrate" command to calculate patch flow rate | maysmech | OpenFOAM | 4 | November 9, 2010 02:39 |
Erosion Rate | dcw | CFX | 0 | August 27, 2008 15:50 |
Erosion rate | prawneater | CFX | 0 | November 24, 2005 13:49 |
