Home > Forums > FLUENT
UDF
Old   September 6, 2005, 07:38
Default UDF
Teresa
I've calculated some variables inside loop "if-else", and now in other loop I want to check the variables I've calculated before, but I don't know why it doesn't works! This isHEAT_H and HEAT_HDH are the variables that my udf calculates, and dQ is I want to calculate using HEAT_H and HEAT_HDH) if{ HEAT_H }else{ if{ HEAT_HDH }else{ in this line the udf set values of HEAT_H and HEAT_HDH=0 and it's not true! dQ=HEAT_H-HEAT_HDH } }
Thread Tools
Trackbacks are On
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 23:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 21:38
Dynamic Mesh UDF Qureshi FLUENT 1 December 2, 2009 01:27
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 05:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 05:01
