How can I get Cp=1 at the stagnation point ?
Old   September 7, 2005, 17:21
Default How can I get Cp=1 at the stagnation point ?
largeeedysimulation
From the flow around a circular cylinder, the pressure coefficient around stagnation area is not 1. As my understanding, it should be 1. Please let me know how to calculate the pressure coefficient from the FLUENT simulation.
I tried to change reference values but it seems not working.
Old   September 7, 2005, 18:03
Default Re: How can I get Cp=1 at the stagnation point ?
zxaar
The value you would be getting is higher than 1, when you refine the mesh near wall, the CP gets to correct values. I use the mesh with yplus less than one, then i get max Cp around 1.05, and the CP values match experimental values.
block-structured mesh for t-junction Robert@cfd ANSYS Meshing & Geometry 20 November 11, 2011 04:59
NO STAGNATION POINT FOR AIRFOIL SIMULATION Rif Main CFD Forum 6 February 4, 2008 07:33
[Gmsh] Gmsh and samplesurface touf OpenFOAM Meshing & Mesh Conversion 2 December 10, 2007 02:27
Stagnation point and other issues Freeman FLUENT 0 December 12, 2005 15:16
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
