UDF problems...FATAL ERROR!
Thank you to all the people that helped me in these days. I'm still having problems with my UDF; now i post it all :
/************************************************** ******************** mut/mu profile ************************************************** *********************/ #include "udf.h" /* profilo per il rapporto di viscosità turbolento */ DEFINE_PROFILE(mut_su_mu_profile, t, i) { real cf, utau, knw, kext, Kturb, mix, Epsilon; real y, delta, uext, x[ND_ND], viscin, iext, cmu, vkc; face_t f; /*costanti*/ #define VISCIN 4.e-05 /*mu*/ #define Iext 0.01 #define uext 1.0 #define delta 0.5 #define CMU 0.09 #define VKC 0.41 cf = 0.045/pow(uext*delta/VISCIN,0.25); knw=(pow(uext,2.)/sqrt(CMU))*cf/2.; kext=(3./2.)*pow(uext,2.)*pow(Iext,2.); begin_f_loop(f, t) { F_CENTROID(x,f,t); y=x[2]; if (y <= delta) Kturb=knw+y/delta*(kext-knw); else Kturb=kext; if (VKC*y < 0.085*delta) mix=VKC*y; else mix=0.085*delta; Epsilon=pow(CMU,0.75)*pow(Kturb,1.5)/mix; F_PROFILE(f,t,i)=F_R(f,t)*(CMU/VISCIN)*pow (Kturb,2.0)/Epsilon; } end_f_loop(f,t) } /************************************************** ******************** UDF for specifying a steady-state velocity profile boundary condition ************************************************** ********************/ DEFINE_PROFILE(inlet_x_velocity, thread, index) { real x[ND_ND]; real y; real ydel; real uset; face_t f; begin_f_loop(f, thread) { F_CENTROID(x,f,thread); y = x[2]; if (y < delta) y = x[2]; else { y = delta; } F_PROFILE(f, thread, index) = pow(y/delta,1./7.); } end_f_loop(f, thread) } /************************************************** ****************** udf_source_term.c line 90 UDF per il calcolo del source term (only 3D) ************************************************** ******************/ real Volume; real ALPHA; real XMIN, XMAX, YMIN, YMAX, ZMIN, ZMAX; real Xg, Yg, Zg, dist; real ny; real d; real d1; real d2; real dx, dy, dz; real p1; real p2; real p3; real xc[3]; real bar[3]; real xc1[3]; real x[3]; real x1[3]; int n; DEFINE_ON_DEMAND(cell_select) { Domain *domain; cell_t c; Thread *t; #define XMIN 1 #define XMAX 3.1 #define YMIN 14 #define YMAX 14 #define ZMIN 0 #define ZMAX 0.3 #define ALPHA 10 /*Calcolo del baricentro del MVG*/ p1=XMAX-XMIN; p2=YMAX-YMIN; p3=ZMAX-ZMIN; Xg=p1/2+XMIN; Yg=p2/2+YMIN; Zg=p3/2+ZMIN; bar[0]=Xg; bar[1]=Yg; bar[2]=Zg; /*Valori iniziali per il confronto del ciclo if sulle celle*/ d=10; d1=0; domain = Get_Domain(1); thread_loop_c(t,domain) { begin_c_loop(c,t) { C_CENTROID(xc,c,t); dist=sqrt(pow((xc[0]-bar[0]),2)+pow((xc[1]-bar[1]),2)+pow((xc[2]-bar[2]),2)); if ( dist < d ) { d=dist; C_CENTROID(xc1,c,t); for (n=0; n <= cell_type_nnodes[(int)C_TYPE(c,t)]; n++) { ny=NODE_Y(n); d2=fabs(ny-bar[1]); if (d2>d1) { d1=d2; } } } } end_c_loop(c,t) } /*Calcolo del volume totale delle celle da selezionare*/ dx=(XMAX-XMIN)/2; dy=d1/2; dz=(ZMAX-ZMIN)/2; Volume=0; thread_loop_c(t,domain) { begin_c_loop(c,t) { C_CENTROID(x,c,t); if ( fabs ( x[0] - bar[0] ) < dx ) { if ( fabs ( x[2] - bar[2] ) < dz ) { if ( fabs ( x[1] - xc1[1] ) < dy ) { Volume=Volume+C_VOLUME(c,t); } } } } end_c_loop(c,t) } } /*PROVA INIZIALIZZAZIONE CAMPO*/ DEFINE_INIT(init_func, domain) { cell_t c; Thread *t; thread_loop_c (t,domain) { begin_c_loop_all (c,t) { C_CENTROID(x,c,t); if ( fabs ( x[0] - bar[0] ) < dx ) { if ( fabs ( x[2] - bar[2] ) < dz ) { if ( fabs ( x[1] - xc1[1] ) < dy ) { C_U(c,t)=100/Volume; } else C_U(c,t)=0; } } } end_c_loop_all (c,t) } } I wrote this UDF to set the boundary profiles at the inlet and to compute a source term for the x-mom eqn. At this stage there isn't the source term because i only want to know if i've selected the right cells where to put it in, so i wrote the DEFINE_INIT to do this check (after the initialization i will plot a velocity contour). The profiles already worked alone in an other UDF so i think the problem is not there. WHEN I INTERPRET THIS FILE, IT WORKS. After that the file has been interpreted i hook the on_demand routine and i have this error: Error: FLUENT received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error Object: () but the initialization works (i need the on demand first). Obviously if i put all together in a DEFINE_INIT macro i have the same error. After this i started the debug of my UDF cutting a lot of parts and i discovered that when i try to run the on_demand the variables that i define in it are not read in the right way, so if i write: #define a 1; doesn't read it and say me that "a = a very big number that i don't remember" (i checked it with a printf command) So now i'm going crazy because i don't know how to proceed. Any kind of help needed...please. Thank you |
Re: UDF problems...FATAL ERROR!
Some news, maybe someone can help me:
I debugged all the UDF and i founded that the problem is the C_CENTROID(x,c,t) command, when i use it i have the fatal error. So i looked inside the metric.h file to see how is build the function C_CENTROID(x,c,t). Doing this i discovered that in this function is used the c_node_loop macro that gived me problems in the last days. Now i would try to see how is build this function inside fluent but i'm not able to do it because i can't find it anywhere. Do someone of you knows where is the relative "something.h" file in which is defined the macro c_node_loop? Or anyway someone knows what is the problem with my UDF? Thanks a lot |
