September 8, 2005, 15:24 |
tricky flat plate laminar flow
hi all,
I have done the simulation of laminar flow over a flat plate but the results are very weird. i gave the BCs: 1. velocity inlet at the entry & freestream(inx-direction) 2. pressure outlet at the outlet with 0 gauge pressure 3. wall with no slip condition only the flow equations were solved but the cf values along the wall as compared to the blasius solution are highly ridiculous. besides, the velocity at some points exceeds the freestream velocity....I know this is very basic... please help.... thanx in advance.............sarat |
September 8, 2005, 23:50 |
Re: tricky flat plate laminar flow
1. Grid may need more refinement , cf is easily to match where first grid y+ less than 5.
2. Overshooting is duo to your grid quality, espicilly aspect ratio that results in numerical diffusion.Kind of a paradox to the refined requirment. Has to trade off. Do not remember in fluent manual what is the recommended aspect ratio. |
September 9, 2005, 02:07 |
hey..i think i found the tutorial for the simulation. following the steps as in it, i find that the BL thickness is higher tahn predicted..... also, the BCs of 'outflow' at the top and te outlet of the plate is different than that I have used...i.e. the pressure-outlet condition...
I would use a refined grid and then check it. I think the recommended aspect ratio is 1.07 thankx...sarat |
September 9, 2005, 11:08 |
I do not know where you got the number 1.07. Anyway it is unrealistic. 1.07 meant you have to always keep the cell squre. I thought AR less that 5 should be OK.
September 9, 2005, 19:35 |
I tried myself a flat plate solution with fluent, I got good match on cf and Nu near the wall, but the match with Blasius solution is not good.
Anybody know of why? |
Display Modes | |
Boundary Layer of Laminar Flow over a Flat Plate | Blasius_Pohlhausen_Crocco | Main CFD Forum | 12 | September 30, 2013 18:35 |
Low Reynolds Number Flow over a Flat Plate | Go | FLUENT | 4 | August 28, 2013 06:19 |
laminar flow on flat plate | AmirFluid | Main CFD Forum | 7 | June 22, 2010 06:49 |
boundary layer trips in laminar flat plate flow | David | FLUENT | 0 | June 23, 2005 12:01 |
2d supersonic flow over flat plate | puzzled | Main CFD Forum | 2 | March 17, 2004 19:07 |
