September 10, 2005, 12:52 |
installation of fluent 6.2.16
hi friends! i have a copy of 6.2.16. i installed that succesfully.then fluent wanted me to specify licence file. i have specified the path of licence file(cd rom/crack/licence.dat), but this error appeared:
"Cannot find license file The license files (or server network addresses) attempted are listed below. Use LM_LICENSE_FILE to use a different license file, or contact your software provider for a license file. Feature: fluentall Filename: C:\Fluent.Inc\license tx86\..\license.dat License path: C:\Fluent.Inc\license tx86\..\license.dat FLEXlm error: -1,359. System Error: 2 "No such file or directory" For further information, refer to the FLEXlm End User Manual, available at "www.globetrotter.com"." any useful help will be apprecite. regards |
September 11, 2005, 07:58 |
Re: installation of fluent 6.2.16
is your fluent a .. edition
September 11, 2005, 11:26 |
yes ztdep,now can u help me please?
September 12, 2005, 14:13 |
Hi
You have written that you are specifying the license file path as cd rom/crack/license.dat Check it whether you've written it write here. Is it cdrom/crack/license.dat If it is this then it means that Software should look for license file in cdrom. But, it won't copy it. Do one thing. When you install fluent, it creates a directory named license in ~/fluent6.2.16. By ~ I mean your home directory. In Windows, it may be, eg., C:/setup/fluent6.2.16 Copy license.dat file inside license folder, and after that start the fluent. It must work Vinod Dhiman |
May 7, 2010, 18:04 |
Rep Power: 15 |
hi there...i have a problem concerning opening the program. i copied the license.dat to the path c:\fluent.inc\license\license.dat and still i cant have the gambit open...the (exceed)(gambit)and fluent are all installed.any ideas?i m using windows 7 (64 bits) can that be the problem?HEEELP PLEASE!!!
May 7, 2010, 18:45 |
#6 | |
Sebastian Gatzka
Rep Power: 20 |
Schrödingers wife: "What did you do to the cat? It's half dead!" |
May 9, 2010, 08:58 |
Rep Power: 15 |
well, i tried all combinations u can think of...exceed then gambit then fluent...gambit,exceed, fluent...etc. but i get nothing still. i was just wondering if those programs are compatible with windows 7? thanks for ur reply by the way
Two questions on Fluent UDF | Steven | Fluent UDF and Scheme Programming | 7 | March 23, 2018 03:22 |
few quesions on ANSYS ICEMCFD and FLUENT | Prakash.Paudel | ANSYS | 0 | August 12, 2010 12:07 |
Fluent 6.3.26 vs 12.1 and partition method | Anorky | FLUENT | 0 | April 27, 2010 10:55 |
fluent installation error | Ramesh.K | FLUENT | 2 | September 25, 2008 20:58 |
tutotial and userguide of fluent 6.2.16 | masood yooceframandi | FLUENT | 0 | September 11, 2005 11:51 |
