September 13, 2005, 09:43 |
Seting up pressure boundaries
I am trying to simulate a flow through a vena contracta. I am getting very confused in setting up my boundary counditions. I have hot gas flowing coming into a chamber at 65psi and then flows through a vena contracta. Once the gas flows through the hole the rest of the chamber is measured at 40psig and then flows out into atmospheric pressure. I am confused on how to set the boundary condition pressures. If I set my operating pressure at 14.7psi, then my inlet gauge total pressure would be 79.3psi, correct? and my supersonic gauge pressure would be the same as my outlet pressure of 25.7 to ensure I have a chamber pressure of 40psi after the gas flows through the hole. Can anyone help verify if I am doing this correct? Thanks.
Pressure enigma. | Sara | Main CFD Forum | 22 | July 30, 2009 04:46 |
Mass & Pressure Boundaries | kantipudi | Main CFD Forum | 0 | February 5, 2009 12:37 |
pressure boundaries | killian | FLUENT | 0 | November 25, 2006 09:37 |
periodic boundaries and pressure correction | Vladimir Fuka | Main CFD Forum | 0 | January 16, 2006 07:50 |
Subroutine for pressure boundaries | Mir | Siemens | 1 | July 27, 2004 17:38 |
