Surface tension options for VOF models
Does anybody know where I could access the surface tension options of the VOF model through the text commands.
The path 'solve/set/surface-tension' given in fluent documentaion does not exist and I could not find those options anywhere. Moreover, I would like to know about experiences in using those options. Thanks, Pierre |
Re: Surface tension options for VOF models
What about define/phases/interaction-domain?
You can access surface tension options also via GUI scrolling down define/phases and then clicking on "interaction". I personally used this option (together with wall adhesion) in an preliminary study on fluid behaviour in microgravity. I know that in ZARM institute (Bremen) they used fluent in 2001 to model such phenomena. I think they also validated a test case but not sure. Cheers Edi. |
thanks for your reply
Actually, I was refering to "hiden" surface tension options that are mentionned in 24.2.8 of Fluent documentation. I explored most of the menus of the interface, but coud not find them. |
Ok, now I got it. Sorry for the delay, I was busy. To tell you the truth, I found out the solve>set>surface-tension options in the TUI without any problem...even without enabling the VOF multiphase model nor inputing the surface tension value in the phases>inteeraction panel... . Are you sure you're working with fluent 6.2? In 6.1 version those options are not available...
Cheers Edi. |
Thanks.
Effectively, I am working with version 6.1.22. I should have think of it !!! |
