A computer to run Fluent - 64 bit?
Old   September 14, 2005, 14:36
Default A computer to run Fluent - 64 bit?
Mike
I'm looking to invest in a new computer to run Fluent using the Windows operating system. Could anyone reccomend a system spec? Please keep in mind that I don't have very deep pockets. Also, what would I need to run a 64-bit version of Fluent? A 64-bit processor, a 64-bit version of Windows XP, and a 64-bit version of Fluent for Windows? Is 64 bit worth it?
Thanks,
Mike
Old   September 14, 2005, 15:06
Default Re: A computer to run Fluent - 64 bit?
Anindya
You can get a dual opteron (64 bit) processor (AMD) machine with around 2-4 GB Ram for around $2000-2500. You would be better off using RHEL 4 (linux), compared to XP in my opinion. You should see some speed up using 64 bit version. Around 1.3-1.5 maybe. Anindya
Old   September 15, 2005, 02:42
Razvan
There is no 64-bit version of Fluent for Windows yet. So if you want to use this version you must use Linux (Fedora Core 4 works just fine).
The main advantages:
- 20-35% speed-up compared to 32-bit version on same case and hardware of course
- 4GB of memory adressable space by a single process, compared to 2GB for 32-bit version (don't neglect this, you might need it some day!)
As for the hardware, I already posted several times my own configuration, just give it a search.
Best whishes, Razvan
Old   September 23, 2005, 10:27
Uffe
64-bit Windows Fluent won't be available until v6.3 is released, which is said to be summer 2006.
Please help: Fluent 12.1 doesn't run on my AMD X4 630 2.8Ghz PC with Window 7 andy.eco FLUENT 0 June 14, 2010 17:16
Run Fluent on a 64 bit machine Fluentuser FLUENT 10 March 17, 2006 10:18
To run FLUENT in a 64 bit machine Rucy FLUENT 1 July 4, 2005 08:31
To run FLUENT in a 64 bit machine Rucy FLUENT 1 June 25, 2005 14:17
FLUENT parallel run Sampath FLUENT 6 November 24, 2004 09:52
