6 DOF udf
Like Tree1Likes
  • 1 Post By Manoj Kumar
Old   September 15, 2005, 13:48
Default 6 DOF udf
Manoj Kumar
Hi
Can anyone send me 6-dof udf code? Please send me at manoj.me@gmail.com
Thanks
Manoj
Old   September 16, 2005, 01:13
Default Re: 6 DOF udf
Manoj Kumar
I wrote the udf after going through Fluent user guide. Can any one go through it and let me know if I am right in calculating force and moment vectors ..
/*Fluent Six-Degree of freedom User Defined Function (6-DOF udf).*/
#include "udf.h"
/*Define mass */
#DEFINE mass 50
/*Define Moment of Inertia about x-axis*/
#DEFINE Ix 5
/*Define Moment of Inertia about y-axis*/
#DEFINE Iy 5
/*Define Moment of Inertia about z-axis*/
#DEFINE Iz 5
/*Define Center of Gravity*/
#DEFINE cg_x 0
#DEFINE cg_y 0
#DEFINE cg_z 0
static real vx = 0.0;
static real vy = 0.0;
static real wx = 0.0;
static real wy = 0.0;
static real wz = 0.0;
DEFINE_CG_MOTION(block,dt,vel,omega,time,dtime)
{ Thread *t;
face_t f;
Node *node;
int n;
real NV_VEC(A);
real Fx, Fy, Fz, Mx, My, Mz;
real dvx, dvy, dvz, dwx, dwy, dwz;
/* reset velocities */
NV_S(vel, =, 0.0);
NV_S(omega, =, 0.0);
if (!Data_Valid_P())
return;
/* get the thread pointer for which this motion is defined */
t = DT_THREAD(dt);
/* compute pressure force on body by looping through all faces */
Fx = 0.0;
Fy = 0.0;
Fx = 0.0;
Mx = 0.0;
My = 0.0;
Mz = 0.0;
begin_f_loop(f,t)
f_node_loop(f,t,n)
F_AREA(A,f,t);
/* x,y,z - components of Force
x-component of force = Pressure on the face * x-component of Area vector
Fx += F_P(f,t)*A[0];
Fy += F_P(f,t)*A[1];
Fz += F_P(f,t)*A[2];
/* Moment (M) = vector product of Force and Displacement vector (F X r);
F = Fx i + Fy j +Fz k
r = (x - cg_x)i + (y- cg_y)j + (z - cg_z)k
Mx += F_P(f,t)*(A[1]*(NODE_Z(node) - cg_z)-A[2]*(NODE_Y(node) - cg_y));
My += F_P(f,t)*(A[2]*(NODE_X(node) - cg_x)-A[0]*(NODE_Z(node) - cg_z));
Mx += F_P(f,t)*(A[0]*(NODE_Y(node) - cg_y)-A[1]*(NODE_X(node) - cg_x));
} end_f_loop(f,t)
/* compute change in velocity, i.e., dv = F * dt / mass
velocity update using explicit Euler formula */
dvx = dtime * Fx / mass;
vx +=dvx;
dvy = dtime * Fy / mass;
vy +=dvy;
dvz = dtime * Fz / mass;
vz +=dvz;
dwx = dtime * Mx / Ix;
wx +=dwx;
dwy = dtime * My / Iy;
wy +=dwy;
dwz = dtime * Mz / Iz;
wz +=dwz;
Message ("time = %f\n", time);
Message ("x_force = %f, y_force = %f, z_force = %f\n", Fx, Fy, Fz); Message ("x_vel = %f, y_vel = %f, z_vel = %f\n", vx, vy, vz);
Message ("x_moment = %f, y_moment = %f, z_moment = %f\n", Mx, My, Mz); Message ("x_omega = %f, y_omega = %f, z_omega = %f\n", wx, wy, wz);
/* set x,y,z-component of velocity */
vel[0] = vx;
vel[1] = vy;
vel[2] = vz;
/* set x,y,z-component of angular velocity */
omega[0]= wx;
omega[1]= wy;
omega[2]= wz;
Mad_Ahab likes this.
Old   September 21, 2005, 04:33
Manoj Kumar
CG location needs to be updated in the previous code ..
Old   April 6, 2017, 13:58
Have a nice time!
Ahmed Saeed Mansour is on a distinguished road
Hello , could you tell me the basics of using the 6 DOF?
Ahmed Saeed Mansour is offline   Reply With Quote
Old   June 26, 2017, 21:36
SJSW is on a distinguished road
The codes seemed OK. But it's for DEFINE_CG_MOTION.
Are the codes applicable for DEFINE_SDOF_PROPERTIES?
Thank you!
SJSW is offline   Reply With Quote
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 21:38
Force can not converge colopolo CFX 13 October 4, 2011 22:03
6 DOF udf Manoj Kumar FLUENT 0 October 17, 2005 07:55
Six dof UDF Dr. John Anttonen FLUENT 0 February 22, 2002 14:47
