-   -   Dynamic mesh udf example (http://www.cfd-online.com/Forums/fluent/37913-dynamic-mesh-udf-example.html)
avant September 15, 2005 15:08
Can anyone please post or direct me towards an example udf for dynamic mesh motion Thanks, Avant
Manoj Kumar September 16, 2005 01:17
Re: Dynamic mesh udf example
Hi
There is an example in fluent tutorial, which uses dynamic mesh. Go through its udf.
Regards,
Manoj
Manoj Kumar September 16, 2005 01:24
Following udf calculates force acting on a regid body and sets its x-component of velocity. At the end of every time step, the udf is used and the mesh is updated.
#include "udf.h"
static real v_prev = 0.0;
DEFINE_CG_MOTION(block,dt,vel,omega,time,dtime)
{ Thread *t;
face_t f;
real NV_VEC(A);
real force, dv;
/* reset velocities */
NV_S(vel, =, 0.0);
NV_S(omega, =, 0.0);
if (!Data_Valid_P())
return;
/* get the thread pointer for which this motion is defined */
t = DT_THREAD(dt);
/* compute pressure force on body by looping through all faces */
force = 0.0;
begin_f_loop(f,t)
F_AREA(A,f,t);
force += F_P(f,t) * NV_MAG(A);
end_f_loop(f,t)
/* compute change in velocity, i.e., dv = F * dt / mass
velocity update using explicit Euler formula */
dv = dtime * force / 50.0;
v_prev += dv;
Message ("time = %f, x_vel = %f, force = %f\n", time, v_prev, force);
/* set x-component of velocity */
vel[0] = v_prev;
