fixing cell values
Old   September 13, 2005, 11:29
Default fixing cell values
Saurav
Hey guys,
Is it possible to fix the static pressure in a fluid cell zone. For example lets pick a cylinder which has a mass flow inlet and a pressure outlet. Now can I create an interior face and fix pressure on that face or pick a layer of hex elements which form a fluid cell zone inside the cylinder and fix static pressure there (I know its easy to fix the velocities for the fluid cell zone but I need to fix the static pressure). Any suggestions!!!!
Saurav
Old   September 13, 2005, 13:56
Default Re: fixing cell values
Amir
I did it by a UDF, use DEFINE_ADJUST macro for that
Old   September 21, 2005, 07:58
kevin
hi Aimir:
Would you please say more about UDF, I meet the same problem but I don't know how to program it in C language. Please show us some similar examples. Thanks in advance.
kevin
Old   September 21, 2005, 08:30
Amir
Hi Kevin, The best way to learn how to develop your own UDF codes is to read UDF manual carefully. There're a bunch of examples there that help you get started. You may also check http://www.fluentusers.com/ to get complementary examples.
Let me know what would you like to do by UDF and I may have something useful for your application.
Cell Reynolds Number laliong Main CFD Forum 12 September 17, 2019 03:18
Dynamic Mesh.. Layering.. cell addition kedarj14 OpenFOAM Programming & Development 0 January 29, 2010 01:48
Cell face values computation un unstructured grids Sergio Rossi Main CFD Forum 2 May 28, 2006 10:04
strain rate at arbitrary position in a cell K. Kevala FLUENT 0 February 4, 2004 17:14
high difference between cell and nodal values Trilok FLUENT 2 November 13, 2003 03:38
