problem with pump as source term
Old   September 19, 2005, 08:54
Default problem with pump as source term
hari
dear all, I have problem in modeling(3D) pump as a source term in the tank outlet. After specifying the mass(kg/m3s) and the momentum(n/m3) in the source term ,the direction of flow for few iterations will be unidirectional. But after few more iterations the flow becomes bidirectional (flow moves away from the source term in both directions)
Please let me know what is the solution for this problem.
regards, hari
Old   September 19, 2005, 11:38
Default Re: problem with pump as source term
Alec Eiffel
should you be adding a mass source here?
A pump should only provide a momentum source and not be adding mass to the flow.
Problem of SOURCE term gradient in UDS wind Fluent UDF and Scheme Programming 6 December 1, 2022 14:21
Source term problem in UEqn of simpleFoam fisch OpenFOAM Programming & Development 1 June 17, 2011 10:57
Sloshing Problem methods.. .mesh motion and Source term lostin4ever Main CFD Forum 1 December 1, 2009 01:02
UDF Source Term Units? Brian FLUENT 1 October 24, 2005 09:15
Problem: buoyancy source term for KE-EP model Andrey V.Ivanov Phoenics 0 May 23, 2003 03:50
