-   FLUENT (
-   -   UDF compilation problem -- "undeclared variable" (
Henrik Ström September 20, 2005 08:26
I would be very happy if someone could help me with this... Probably not too complicated since I am quite new to C programming.. I am working on a bigger UDF but to isolate the problem I have tried to compile smaller parts of code, but I still can't see what I do wrong.
When I try to load a UDF I've written into FLUENT (via Defined->User-Defined->Functions->Interpreted) I get an error message during compilation: "line 7: P_CURRENT_LAW: undeclared variable".
This is when I'm trying to use the P_CURRENT_LAW(p) macro inside a DEFINE_DPM_SWITCH command. The code is more or less directly copied from the UDF User Guide, only slightly simplified:
#include "udf.h"
#include "dpm.h"
if(5.0 > 1.0)
What is wrong?? I get the same error message when I try to use P_MATERIAL(p) inside a DEFINE_DPM_SCALAR_UPDATE command.
In other parts of my bigger UDF I use macros such as P_RHO(p), P_MASS(p), P_INIT_MASS(p), VaporizationLaw(p) etc without trouble.
Any help is highly appreciated!
Thank you very much, Henrik
Henrik Ström September 21, 2005 05:25
Re: UDF compilation problem -- "undeclared variabl
I solved this problem by compiling the UDF instead.
