UDF compilation problem -- "undeclared variable"
Old   September 20, 2005, 08:26
Default UDF compilation problem -- "undeclared variable"
Henrik Ström
Hello!
I would be very happy if someone could help me with this... Probably not too complicated since I am quite new to C programming.. I am working on a bigger UDF but to isolate the problem I have tried to compile smaller parts of code, but I still can't see what I do wrong.
When I try to load a UDF I've written into FLUENT (via Defined->User-Defined->Functions->Interpreted) I get an error message during compilation: "line 7: P_CURRENT_LAW: undeclared variable".
This is when I'm trying to use the P_CURRENT_LAW(p) macro inside a DEFINE_DPM_SWITCH command. The code is more or less directly copied from the UDF User Guide, only slightly simplified:
#include "udf.h"
#include "dpm.h"
DEFINE_DPM_SWITCH(dpm_switch,p,coupled)
if(5.0 > 1.0)
P_CURRENT_LAW(p) = DPM_LAW_INITIAL_INERT_HEATING;
else
P_CURRENT_LAW(p) = DPM_LAW_VAPORIZATION;
What is wrong?? I get the same error message when I try to use P_MATERIAL(p) inside a DEFINE_DPM_SCALAR_UPDATE command.
In other parts of my bigger UDF I use macros such as P_RHO(p), P_MASS(p), P_INIT_MASS(p), VaporizationLaw(p) etc without trouble.
Any help is highly appreciated!
Thank you very much, Henrik
Old   September 21, 2005, 05:25
Default Re: UDF compilation problem -- "undeclared variabl
Henrik Ström
I solved this problem by compiling the UDF instead.
/Henrik
A problem about 'printf' and 'Message' in UDF. LICH Fluent UDF and Scheme Programming 2 May 2, 2013 02:45
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
what's the problem with my udf zzyan FLUENT 0 November 4, 2010 03:56
Help! Compiled UDF problem 4 Wave tank tutorial Shane FLUENT 1 September 3, 2010 02:32
UDF variables F1, y / problem with UDF Fabian FLUENT 6 June 2, 2003 10:22
