January 24, 2011, 08:03 |
turbulent viscosity
EH
Rep Power: 15 |
I am solving an unsteady problem and I get the warning message: turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1 cells which appears once at every 10 to 20 time levels. This disappears after some iterations but keeps popping up at new time levels. My question is, given that this happens only in 1 cell and that the message disappears after further iteration and it only occurs every 10-20 time steps, is it a critical issue? Thank you. Cheers, EH |
reversed flow at pressure inlet and turbulent viscosity is limited.... | cfdiscool | FLUENT | 10 | June 10, 2015 06:15 |
k-epsilon problem: non-physical turbulent viscosity production in coaxial free-jet | Felipeb | Main CFD Forum | 1 | July 26, 2010 17:02 |
Turbulent viscosity and shear rate | shib | FLUENT | 0 | June 22, 2010 12:44 |
setting value of turbulent intensity and turbulent viscosity ratio in wind tunnel | nuimlabib | Main CFD Forum | 0 | August 4, 2009 00:05 |
Problem of Turbulent Viscosity Ratio Limited | David Yang | FLUENT | 3 | June 3, 2002 06:13 |
