October 3, 2005, 02:45 |
How to solve turbulent viscosity limited to
turbulent viscosity limited to viscosity ratio of 1.000000e+005 in 99117 cells how to slover the problem
thanks |
October 3, 2005, 03:01 |
Re: How to solve turbulent viscosity limited to
search the forum with name zxaar and viscosity ratio, long ago i wrote a lot on it. might be help.
Another thing is do u get this problem as soon as you initilise or from the first iteration. If so, then initialise the k and e as k = 0.0001 and e = 0.001, this shall not give you ratio warning if every thing is okey. |
October 5, 2005, 04:58 |
thanks your answer! some one have told me goto SOLVE....CONTROLS.....LIMITS .. and change the the maximum turbulent viscosity ratio to 1.0e10+07. do you think it fine the problem?
thanks |
October 5, 2005, 05:17 |
well its not a good idea, because you see, as the viscosity ratio increases the effective viscosity increases, for two equation models the max ratio is mostly around 5000-10000, it could be more but usually it is around this. (effective viscosity affects your convergence very much). second issue is how fluent restrict the ratio, it does this by modifying turbulent viscosity and dissipation, that is k will be same, only epsilon will be adjusted for k-e model, now increase in limit means, dissipation max value is increased. Higher the dissipation (increasing to 10^7 etc) lower your chance of getting convergence with this model.
best bet is to restrict the ratio to maximum possible (realistically ) values. So if i aspect 5000 as max ratio, i would restrict it to 7000 max), its been observed that in some cases this approach result in covergence. |
turbulent viscosity limited to viscosity ratio | Elizabeth | FLUENT | 13 | December 16, 2014 08:57 |
Turbulent viscosity limited to viscosity... | Cyril | FLUENT | 16 | October 4, 2007 06:12 |
how to solve turbulent viscosity limited ? | daniel sin | FLUENT | 4 | March 7, 2006 14:22 |
turbulent viscosity limited to viscosity ratio | mukkarum | FLUENT | 3 | May 11, 2004 04:05 |
Turbulent Viscosity Ratio | xiang | FLUENT | 3 | May 20, 2003 12:46 |
