Home > Forums > FLUENT
Modeling of melt pool geometry!
Old   September 29, 2005, 10:18
Default Modeling of melt pool geometry!
Fareed Qureshi
Hi, i have tried to model the melt pool geometry in laser processing using FLUENT. Following are the case that i did; 1. First of all, i ran the simulation just to check heat transfer (using only energy equation). it was perfectly fine. 2. Second, i turned on the flow equations and Melting/solidification as well, since i have to check the velocity profile in the melt pool. At this stage, the solution is diverged. i have changed under relaxation factors as well as residuals, but still having same problem. Anyone who has got some idea or anyone who has worked on this before, any help would be highly appreciated, regards, Fareed
Old   September 29, 2005, 10:35
Default Re: Modeling of melt pool geometry!
lana
check out the metal properties. there is a sudden change between solid and liquid state and could create numerical problems at the interface... you should smoothen the jump.
Old   September 30, 2005, 08:56
Fareed
thanks for you reply. i am using viscosity as a function of temperature. from 300 to 1743 degree K, it is 1e08. from 1745 onwards it is 0.0067. do you think this change of viscosity in 2 degrees can cause a problem ? regards.
Old   September 30, 2005, 11:32
lana
very probably. you jump of more than 10 orders of magnitude...
you should not set a very different viscosity for the solid phase. Try the solidification/melting model. or add a sink momentum like in the solidification example in the fluent manual. however it has to be calibrated.
Old   January 28, 2011, 11:44
Md. Minhaj Alam
minhaj_iut is on a distinguished road
Originally Posted by Fareed Qureshi
;124623
Have done the simulation?
Regards
Minhaj
minhaj_iut is offline   Reply With Quote
Old   January 28, 2011, 12:03
Default hi
abdul moqeet hai
abdul moqeet is on a distinguished road
dear Fareed can you please tell me your email id i am to share some data with you...
regards, moqeet
abdul moqeet is offline   Reply With Quote
Thread Tools
Trackbacks are On
Importing CAD geometry and Editing edges to match Ahmed CFX 15 March 21, 2016 13:39
[ICEM] O-grid around wing geometry Anorky ANSYS Meshing & Geometry 12 August 17, 2011 21:28
[ICEM] Ship Hull imported geometry nuovodna ANSYS Meshing & Geometry 0 February 25, 2010 11:09
Simulation of Flow through Complex 3D Geometry EmersonKB CFX 5 July 2, 2009 08:17
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
