October 1, 2005, 16:02 |
heat transfer
I have a 2D geometry and I want to study temperature profile in solid and fluid.I set wall ( thickness=0) the b.c. between solid and fluid.I'd want to know if I must turn on planar conduction (or it's possible only in 3D geometry?) thanks
October 16, 2005, 02:15 |
Re: heat transfer
Shell/Planar conduction is activated only for 3D cases. And there also, it will have any meaningful effect only if the wall thickness is set to some non-zero value. |
Two-sided Wall Heat Transfer BC - No Separate Solid Mesh and No Heat Transfer Coeff | swahono | OpenFOAM Running, Solving & CFD | 10 | October 15, 2018 05:43 |
Convective / Conductive Heat Transfer in Hypersonic flows | enigma | Main CFD Forum | 2 | November 1, 2009 22:53 |
How can I increase Heat Transfer at Domain Interf? | B.Simon | CFX | 3 | October 28, 2008 18:53 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
