Non-premixed comb. temp prediction; PDF problem
I am doing a steady state simulation of combustion in combustion chamber. Fuel is liquid diesel, injected by pressure swirl. The problem is that I do get too high temperature values on the walls of the air blast. 3200K is far too high. The maximum value calculated by the PREPDF was determined to be 2274K. Any suggestions? Is it due to the wrong species chosen in PREPDF? Also, I am unable to read either the pdf table or the input file into the prepdf once i create them. It says couldn't determine the file format and unable tor ead file. Thank You in advance for any suggestions. |
Re: Non-premixed comb. temp prediction; PDF proble
For high temperature flames (>1500K) dissociated species become important so you will have to include some of them in your pdf. I would add at least OH, O(atomic) and H(atomic) to account for the dissociation of water. Other intermediate species you might consider are CH2O,CO,HNO2 and H2O2.
Good Luck RoM |
I will be trying this shortly. Thank You very much. As for O and H however i think I did include them. Problem is I cannot look up the lookup table in PREPDF:)
I had such problem !
Try this in PrePDf Display-Options-Rendering and then check Fluent stroked font Mary |
I tried it, unfortunately it did not help.
