September 28, 2005, 03:48 |
heat transfer
I want to study the heat transfer in solid and fluid.I defined the interface between solid and fluid as wall and Fluent created a shadow wall.I defined wall and shadow wall "coupled" but in the solid the temperature profile is only horizontal.Why?Where is the error?Can someone help me?And Fluent can study heat transfer in solid or only for fluid? Thanks
October 5, 2005, 12:17 |
Re: heat transfer
You need to define the solid as a zone (while creating geometry in Gambit), then specify its boundaries as walls. You need to pick a material for this solid zone, and specify boundary conditions, e.g. fluiid-solid interface as coupled and solid-air interface as convenctive. Hope this helps.
-R |
Two-sided Wall Heat Transfer BC - No Separate Solid Mesh and No Heat Transfer Coeff | swahono | OpenFOAM Running, Solving & CFD | 10 | October 15, 2018 05:43 |
Convective / Conductive Heat Transfer in Hypersonic flows | enigma | Main CFD Forum | 2 | November 1, 2009 22:53 |
How can I increase Heat Transfer at Domain Interf? | B.Simon | CFX | 3 | October 28, 2008 18:53 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
