Fluent- Error: Null Domain Pointer
Like Tree1Likes
  • 1 Post By sheaker
Old   October 5, 2005, 07:38
Default Fluent- Error: Null Domain Pointer
Mary
I am trying to model low temperature boiler. The mesh was successfully written. And when I open 3D Fluent and try to read my .msh file I got this message
WARNING: cell 509862 of thread 2 has NULL face pointer 5.Error: Build_Grid: grid error.
Clearing partially read grid.
Error Object: ()
Please can anyone explain to me what does it mean and where the problem is ??
Thanks in advance !
Old   October 5, 2005, 09:13
Default Re: Fluent- Error: Null Domain Pointer
Thierry BERNIARD
Hi ! Did you try with ascii msh files ?
Old   October 5, 2005, 10:41
Mary
Yes and I got the same..
Building...
grid, Error: Null Domain Pointer
Error Object: ()
I meshed the geometry of my boiler twice. Everything seems to be OK. Gambit exported mesh without errors ! I don't know what else to do !!
Old   October 5, 2005, 11:13
Thierry BERNIARD
i have already had this problem....but i thought it was just a ascii/binary format error.... Is it a windows or unix fluent version ? Did you try to read th msh file with tgrid ? Did you check the mesh with gambit ? (skewness, aspect ratio...)
Old   October 5, 2005, 22:38
ztdep
i also have met this problem, i regenarate the grid ,the the problem dispear
Old   September 21, 2011, 09:26
tianxingjian
twink_zzq is on a distinguished road
Hello,have you resolve the problem?I also meet the same problem,thank you!
twink_zzq is offline   Reply With Quote
Old   October 12, 2011, 22:43
Default Null Domain Pointer
myty is on a distinguished road
I tried it but still have problem, so could you tell me how to do it
Originally Posted by ztdep
;124814
myty is offline   Reply With Quote
Old   January 3, 2013, 11:47
peyman
pzahedi is on a distinguished road
I've had a same problem with 3d mesh then I used smaller tri mesh size to remove this error
pzahedi is offline   Reply With Quote
Old   January 5, 2013, 03:13
SSL
msaeedsadeghi is on a distinguished road
It is because of error in mesh.
msaeedsadeghi is offline   Reply With Quote
Old   June 12, 2014, 14:37
AZ
mjthomp3 is on a distinguished road
Originally Posted by Mary
;124776
Error Object: ()
Thanks in advance !
i got the same error.....
mjthomp3 is offline   Reply With Quote
Old   May 12, 2016, 14:53
Default fluent-error-null-domain-pointer
  #11
alev alev
alev is on a distinguished road
go to your case and
Save as Fluent Input Files (*msh)
alev is offline   Reply With Quote
Old   September 19, 2017, 00:41
sheaker's Avatar
Oskar
sheaker is on a distinguished road
I had the same problem till today. For me solution was to use Gmesh to export mesh in Nastran Bulk Data File.
Then fluent was able to load mesh.
Oskar.
saatt likes this.
sheaker is offline   Reply With Quote
Old   February 28, 2020, 10:44
Default It works
  #13
saatt is on a distinguished road
Originally Posted by sheaker View Post
i had the same problem till today. For me solution was to use gmesh to export mesh in nastran bulk data file.
Oskar.
done........................
saatt is offline   Reply With Quote
.msh file cann't be by Fluent nchuche FLUENT 1 June 29, 2010 10:38
null domain pointer - opening a gambit mesh kassab FLUENT 0 June 4, 2010 12:33
On Bug of Fluent 12.0 lzgwhy FLUENT 0 August 26, 2009 06:41
How to change domain extents in fluent kbs FLUENT 4 April 26, 2008 16:32
Null Domain Pointer Domi FLUENT 1 November 11, 2004 12:23
