Turbulence modelling error
Old   October 5, 2005, 10:02
Default Turbulence modelling error
Derick
Hey guys,
I am a newbie and I was trying to do a turbulence modelling. The flow is inside a large duct and the velocity is very high. I was modeling the 2d case and prepared a udf for inlet velocity, dissipation rate and turbulent kinetic energy as explained in the user guide. As i started the iteration, even before it goes through the first iteration, it gives me this error:
turbulent viscosity limited to viscosity ratio of 1.000000e+005 in 341000 cells
I tried to change the limit of viscosity ratio to a higher value, but still it gives me a similar error.
Any thoughts?
Thanks in advance,
Derick
Old   October 5, 2005, 10:21
Default Re: Turbulence modelling error
RoM
Common question, just scroll one page down to find this thread
http://www.cfd-online.com/Forum/fluent.cgi?read=31826
And a little forum search will get you alot of good answers like this one from zxaar
http://www.cfd-online.com/Forum/flue...cgi?read=28356
RoM
Old   October 5, 2005, 10:48
Derick
Thanks RoM...that helped me and I got it to work
Derick
nonNewtonian viscosity model mhassani OpenFOAM Programming & Development 5 January 7, 2013 09:27
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 06:25
error while running paraFoam! padmanathan OpenFOAM 9 October 13, 2009 05:17
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
