fluid/structure interaction(FLUENT/LS-DYNA) help!!
Old   October 6, 2005, 13:12
Default fluid/structure interaction(FLUENT/LS-DYNA) help!!
MAOMETTO
i'm working on a project that deals with fluid structure interaction. the project is to model a volume in GAMBIT and mesh it, export it to FLUENT to simulate a flow on the structure and analyze it, export the pressure loads on the structure to LS-DYNA for deformation simulation and re-import deformed mesh and volume for fluid analysis. so its basically a coupling between programs to do fluid structure interaction(FSI). the problem is i'm working with another student who uses LS-DYNA and i'm using GAMBIT/FLUENT. does anyone have any straight forward procedure to transfer pressure grid from FLUENT to LS-DYNA and then re import deformed mesh from LS-DYNA to fluent??? if you anyone did this simulation before, can you tell me how u did it by a simple example such as a simple solid cube under deformation. thanks
Old   October 6, 2005, 15:45
Default Re: fluid/structure interaction(FLUENT/LS-DYNA) he
Ogbeni
You need a coupler between your CFD and FE programs. It may be that Fluent does not work with LS-DYNA. I think Fluent works with ABAQUS though. You will need a special license from Abaqus and possibly Fluent. Go here and find out more info, its a big undertaken if you have never done it before:http://www.scai.fraunhofer.de/mpcci.html
FSI using cfx and ansys vs ls dyna or dytran HAYATE CFX 1 September 21, 2007 15:11
FSI using fluent and abaqus vs ls dyna or dytran HAYATE FLUENT 2 September 18, 2007 08:16
FSI using abaqus and star cd vs ls dyna or dytran HAYATE Siemens 0 September 16, 2007 03:27
question about 3d dyna mesh xuzhang FLUENT 1 November 2, 2004 16:48
PhD...in Fluid/Structure Interaction related topic Aamir Main CFD Forum 5 March 13, 2003 11:05
